Sorry havent been on for a while, just been busy with work and the usual stuff.
Managed to get the new truck back in one piece ( using Greecysurf route to Latina italy
, well just about as the Satnav went wonky a few times) but i have been having a few issues with it that i was hoping that you lot could point me in the right direction with...ok well here goes
First of all i know it has the aerodynamics of a brick and im no speed freak and its quite a big truck but it will only do about 70 happily (Speedo in km) and have worked out with the tyres (35's) its actually about 80 but even so at that speed the revs are on about 3000 and it still feels like it wants to go but has nothing to change up to if you know what i mean. Also if you run it at that speed for a while the transmission tunnel gets roasting and the temp gauge creeps up a bit (never let it get past the little temp icon even through the alps), i did have 4 tyres in the back on the way over plus spares but it still does the same unladen...well it does have my fat arse to drag about i suppose
Have checked the ATF and the level seems ok if a little burnt (just driven about 2200Km though some big mountains so not that worried about it or the head…well touch wood).
Checked for loose wires etc but cannot seem to find anything that i havent already re-connected.
No engine check light on (its working as it comes on when you initially turn the key).
Doesnt seem like there are any leaks apart from a small one on the ATF cooler but that is just on the hose connection (over tightened jubilee clip).
Starts ok after changing the glow plug relay and isn't lumpy on startup although it does kick out a bit more unburnt fuel than the other one (glow plugs changed in Jan (still shiney and 80A fuse ok).
Anyone any ideas?
Other things are the fogs / driving light / rear window (works with key), dont work but i think thats just a matter of chasing down the wiring (fuses all ok).
Only other thing is on the steering column is rock solid and i only ask this as on the one on the black one is really flexible on the 'shaft assembly steering intermediate number 2' http://www.toyodiy.com/parts/p_J_199...KPQT_4501.html where the rubber doughnut bit is..... So i presume i need a replacement for the black one?
Ta in Advance folks!
Rob
