hi all
i have a problem with my air con
the pump is not cutting in , i have fitted a replacement pump as the old one the pulley had failed,i have regased it ect but still does cut in
the single wire to the pump, should it have a 12 v feed to the pump as mine does not have any voltage feed to this wire , does this mean a poss sensor fault, i have looked at all the fuses which are all ok , but cannot find a seperate air con fuse in any of the 2 panels?is there a seperate fuse holder somewhere?
your advise please
your advise please
