Got my truck back I now have two problems
vibration on acceleration from standstill which goes on the over run. The second when you put the gear lever in park the key does not rotate in the switch to the point where it can be removed the lever also does not lock in the park position.
Any ideas I am going back to the garage tomorrow, I am thinking prop shaft out of balance on the firsts haven’t a clue on the second.
