Hi guys'n'galls
Here's a tip for all you "bleeders" out there.
Loosen the bleed nipple first, then press the
brake pedal to the floor and wieght it down,
or use a piece of steel pipe to keep it there.
It will prevent all the fluid draining from the
master cylinder, and creating probs later on.
Hope this helps, (it does work).
Gman.
Gman.
.... i just hope mot man likes my work
