My surf is still stuck in 4wd, just changed the vac pump on the alternator, checked all the vac pipes and all is well, getting good vacuum from the alternator itself, all the pipework into the innerwing and backout of the innerwing.
Now i dont know the ins and outs of the system but the solonoid on the front diff has vacuum going to it but not away from it and there is no vacuum to the solonoid on the back of the t/box.
Also im getting no clicking when i press the button on the transfer lever, but the relay under the steering column clicks when i move the transfer lever.
Any advice is gratefully recieved as im at my wits end now, luckily the wife is off work so i can use her car but the surf has been off road for over a week now.
cheers james
cheers james
