Bronze bush problem
  • Bronze bush problem
    I changed my bronze bushes this afternoon, but I can't get the driveshafts back in (hubs are off the truck just now).
    Has anyone had problems like this before? Do they need reamed out, or should they just fit? If they need reamed, what do they need reamed out to?
    Just make sure the shaft is clean and smooth, smother it with grease and it'll slide in easily.
      I'll have another go tomorrow, if the rain goes off!
        Whilst you're here, do you still need that Lexus AFM?
          No, I just wanted to know the serial/part number on the part the multiplug fits onto.
            Ah, OK. And the TPS plug?
              Oh yeah the plug, I need the plug. Got any nuts?
                I have them somewhere, just not sure where. I'll find them tomorrow. PM your address and I'll post them down.
                  is there a step by step write up on changing these bushes
                  thanks in advance
                    thanks in advance
                    Somebody did a writeup on em, Popeye I think ....
                    You'll have to search as I can't remember where or when ...
                    Jess
                    "Cos short cuts can cost more in the long run"
                    Buncefield Burner
