just wondering whats the best cure for this ailement shocks seem good would a set of springs off milner fix the problem ??????
ln130 saggy arse syndrome
New rear springs mate, check out this little thread on my truck.Originally posted by rodsurf View Postjust wondering whats the best cure for this ailement shocks seem good would a set of springs off milner fix the problem ??????
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=63664
Your not far from me if you in Hollywell, I'm in Llandudno.
peace
calBala Mud, best underseal there is, only £30 per application.
www.thecellardwellers.co.uk
roughtrax is better than milner springs mate and they do the 2 inch lift in the spring as standard!!! i had to send my milner springs back after 6 months and got a new pair thru warranty lolOriginally posted by rodsurf View Postcheers for the link pal have looked and will get some h/d springs off milner i think yeah not far at all and tbh the wife works at somerfield in pensarn
1992 hilux surf ssr-x 2.4 auto 2nd gen LN130
http://cornishhostingcompany.co.uk/support/aff.php?aff=005
[LOOP]Springs hold the truck up and absorb shock etc. before it gets to (in this instance) the truck. Dampers have nothing to do with ride hight, they merely control the spring oscillations.[/LOOP]Do you know that, with a 50 character limit, it's
Originally posted by pauly View Postroughtrax is better than milner springs mate and they do the 2 inch lift in the spring as standard!!! i had to send my milner springs back after 6 months and got a new pair thru warranty lol
ok so milner springs arent the best bu if i get 2inch lift ones from rough trax wont the truck look a bit high on the back and i guess there will be differences in handling because of the lift on the back ?????
Originally posted by BUSHWHACKER View PostRead the item's descriptions thoroughly.
Lift springs = lift but same comfort. You will need longer travel dampers too.
Uprated springs = standard height but firmer. Can be used with standard dampers.
ok ok having a blonde moment lol all i want is some firmer springs sound as a pound will go shopping when i get paid
