gen II diffs?
  • gen II diffs?
    I have a 1994 KZN130 with a KZ1TE engine in it. Is this a GenII and if so what diffs should be on it? I know the rear is an LSD and what is ADD?
    Just checking that all is as it should be. Now it's all up and running, I have to test it's towing and boat launching ability against my V8 discovery and keep whichever one is the better. I hope it's the Surf.
    ADD is how the front axle connects when you switch on 4wd. its a coller the front axle that slids to connect the long side drive shaft.
    It replaces the old manual or crappy auto hubs on pick ups and older Surfs, and allows you to shift from 2wd to 4wd at speed without shreading gears or stopping and getting out to switched manual hubs on.
    How bigs your boat? The LR can legally tow double what the Surf can, and the V8 is a strong if thirsty motor.
    But the Surf will get you home every trip, unlike the LR... lol
    I'd have the Surf anytime, even if its technically towing to much, they never look it with decent springs on the back.
      I reckon the boat weighs the same as the Surf. It certainly feels thay way. I will just take it easy and get an oil cooler.
