1st Question - is it worth fixing or sell as is?
here it is
If i go ahead i will be doing the work my self
Parts needed
Head skim?
Gasket
Belt
Thermostat
Oil
Radiator Fluid
Parts maybe needed
Water Pump
Head?
Other parts needed
Service kit
Down pipe
Roughtly £150 from millners off road Head Skim £100ish
wot do you think guys should i fix or quit now also if i do fix it is there any thing else i need or may need?
here it is
Parts needed
Head skim?
Gasket
Belt
Thermostat
Oil
Radiator Fluid
Parts maybe needed
Water Pump
Head?
Other parts needed
Service kit
Down pipe
so strip it 1st i did see a few drops of oil when it went
