KZN185 exhaust - Where to buy?
  • KZN185 exhaust - Where to buy?
    Hi all. Just noticed my rear box is a bit rotten. Need advice on replacement, who, where, how much etc. Much obliged on any advice given. Cheers.
    Richie
    Google Roughtrax or Milner 4x4.
      Got my LN130 pipe from Roughtrax www.roughtrax4x4.com - it was 'clone' and actually fitted really well - but it was only the back section, so no worries about feeding it up to the manifold. Don't forget the rubber dampers if yours are worn / missing, and the gasket rings too. Or get a stainless one fabbed up if the £ stretch that far. in the LONG RUN it'll be worth it, but then these trucks are quite old already....
      If you're gonna be a bear... be a Grizzly.
        Nice one lads thanks. Has anyone bought one of the Milners ones? I wonder if they're a good fit....
          richie
          i fitted a complete Milners exhaust to mine over 2 years ago. Only thing I didn't use were the gasket rings, choosing a good bead of exhaust paste instead. It fitted perfectly, all lined up and still going strong.
          At the time they were on offer and I think the whole thing came in less than £150.00 delivered, not sure now. Also, don't take the price of the website, ring them up and more often that not, you will get some discount
          hope this helps
          hawaii
            The KZN185 Surf Exhaust is the same as a 90 series Landcrusier Colarado of a similar year so any exhaust outlet can get them, the earlier model KZN185's did not have the small resonator in the tail pipe which is in the Colarado tailpipe but the later models had them however the pipe still fits with the resonator.
            ionic SURFactant
