Power Steering Pump Seals
  • Power Steering Pump Seals
    I know you can get the seal kit from R/trax for the above, but is the job of replacing them a fairly staright forward one. Tony N, I think you have done a few of these and have put something here before but I can't find it!
    Cheers, Nick
    "The force will be with you, always!"
    Its not 'hard' just be careful pulling it apart and keep all the bits in order, and steady reassembly not to nick the new seals as you put it back together.
      Cheers Tony, is the pump easy enough to remove from the truck?
      Cheers, Nick
        This has been posted here before..
          Thanks for this, that's handy too,
          Cheers, Nick
