Which Lubricant?
  • Which Lubricant?
    What is the best oil/grease/lubricant to use on the tailgate window mechanism?
    Cheers, Nick
    "The force will be with you, always!"
    I use spray white grease on the mech, and silcone on the window rubbers.
      Thanks Tony. I use the silicone rubber spray its good stuff, and will pop to Halfrauds and pick up some white grease later,
      Cheers, Nick
