CV Joint removal
  • CV Joint removal
    How the feck does the outer cv joint come off the halfshaft?????
    I can see from the new one that the cv has a female spline in it but i cant get the old one off????????????
    Is it simply brute force or is there a way to strip and undo it further
    I ve got it stripped to this stage
    4th photo down on Ian's thread...
    http://www.hiluxsurf.co.uk/forums/showthread.php
    Alan
    Circlip?
    http://www.toyotasurf.asn.au/techsite/cvjoints.htm
      Replied on the dark side!
      Cheers Vince
        current situation.....
        Cant see any way there can be another circlip in there!!!
        Alan
          It looks a bit like some of the old joint has fused?
          I know nothing btw, just a newb looking at a picture Oo
          peace
          cal
          Bala Mud, best underseal there is, only £30 per application.
          www.thecellardwellers.co.uk
            take of outer circlip and use the pipe trick.
            http://www.youtube.com/watch?v=pTooP...eature=related
            Alan
              Thanks for the link Al, wish i'd seen it earlier.
              Took the whole thing to a mates workshop so i could put the shaft in a sturdy vice.
              Took a lot more beating than that pipe trick to get it off as it's had no grease in it for quite a while by the look of it!!
              Alan
