Hi,
I have been having a problem with my rear window on my LN130 Surf.
It operates fine but stops about an inch from the top.
I have read all the posts regarding rear window problems and have check the metal runners and plastic wheels, they seem fine.
The teeth on the mechanism also look ok, everything is well greased and the motor is tight ( I have previously had problems with the motor working loose).
I cant see an obvious problem and think I am probably going to need a new mechanism, does anyone have any other suggestions ( could it be worth removing the motor for a closed look) or a mechanism for sale.
I would message stormforce (but am not allowed to as a new user) as I have seen he has offered them on the forum before.
I also need a lense for the passenger side bumper indicator lamp if anyone can help.
Many thanks in advance.
