3.0lt wont start
  • 3.0lt wont start
    Cranks over just fine but will not start, There is no visible sign of the glow plug light coming on and no audible click from the glow plug timer/relay.
    There is no power/signal going into the glow plug relay but when the relay is bridged the glow plugs work and draw current, I have checked the obvious like the fuses etc and they check out ok. Also there is no power to the fuel pump, I have got diesel at the pump inlet but nothing being delivered under engine cranking.
    Any suggestions of where to start would be much appreciated.
    Has anyone got a comprehensive wiring diagram?
