hi can anyone help my glow plugs are not staying on long enough is there a timmer anywhere or a relay that controls the lenth of time cheers
glow plug time
Just had a thought. Are you using a multi meter or a light to check the glow plug rail? There are 2 voltages supplied to the glow plugs (10.5 & 6.5 I think) so only the 10.5 will light a test lamp.
That doesn't explain the relay only energising for a few seconds though. I take it mine was the same?Do you know that, with a 50 character limit, it's
not sure if the 3 gen is the same but the 2nd gen lighton the dash goes out within a second, you then wait 20 seconds, hear a click from the passenger footwell turn th key and it starts first go.
I think the coiled spring dashlight is just to let you know the system has power, the clicking relay lets you know the stuff is warmed up. Hazzo
I hear the click long after the light goes out on my 2nd gen, then a beeper sounds like the reversing one except a continous tone ( like door open left lights on) and pop starts first time.
Got my electric ariel working too now
peace
calBala Mud, best underseal there is, only £30 per application.
www.thecellardwellers.co.uk
It SHOULD be ready to start when the light goes out, waiting for the click just means the plugs have had longer to glow for, and get a little more heat into the swirl pots for when you start it.
The down side of waiting for the click is they are on for a shorter time once its started, cos normally it would be running by then,so may be a little lumpy initially.
but a longer wait before starting will help an older worn engine start better no doubt.4x4toys.co.uk - Keeping you on and off the road...
