Hi Tony,
In a search I read that you have fitted 4.88 gears for your 33's. I was planning to do that as I have them on my 2.4 and can just swap the axle / front diff with my 3.0. (or sell my 3.0's lsd and front diff and get the 4.88's from a breaker..blah blah blah.. )
However I also read a thread where you say the 4.88's give a hit on fuel economy and 4.5's would be better ? (4.88's more suited to 35's ? )
Can you shed some light for me as my surf is not a daily driver, but when used it covers enough miles to make fuel consumption a factor ?
I will be using it in the mountains in Spain / France / Italy if that has a bearing on gear selection.
Cheers,
Good to see you back on the spanners btw.
Rob.
Cheers,
Rob.
