3rd Gen Steering Wheel removal
  • 3rd Gen Steering Wheel removal
    Hi,
    My 3rd Gen came with a small "boy racer" type steering wheel (in red leather!), I am going to replace it with an original wheel (including the airbag), which I have got from a breakers.
    To the fit the orginal back on - do I just prise off the horn/air bag cover the to the get to the centre/spline part? I assume the airbag has an electrical connection?
    I think the current one should come off pretty easly - it just has horn/cover attatched by allen bolts, I guess the centre nut will be under that.
    Cheers,
    Paul
    What a breeze that was!
    Disconnect battery
    Remove two star head bolts holding the airbag unit/horn push
    Unclip two electrial connectors
    Remove centre/steering column nut
    Reversve to re-fit.
    Job done...
