HELP !!! my abs light has come on !! i got a third gen 3.0td, is this a expensive toyota garage fix ?? back wheels lock up under not so heavy breaking !!!! cheers
Could be just a sensor fault or dirty reluctor ring (toothed ring) on the axle/hub that the sensor er, senses.
Is the engine check light coming on?
I'm only in Abercarn if you want me to have a look.
