Can it be done anyone fitted uk axle lsd into a surf, are they diff ratio or completely different axles?
UK LSD in A surf?
They are all the same, assuming you're talking about a 4Runner diff, up to 96 all surfs/4runner/pickup diffs are interchangeable.
There are 4-5 different gear ratios though, do you need a matching front diff if its not the same, or swap the gears to the LSD, but thats a specialist job.4x4toys.co.uk - Keeping you on and off the road...
