Hi People
Need a bit of help With my 1994 3.0d Hilux. Firstly the whinning when under hard acceleration or going up a hill, seems to be coming for behind the dash obviously from engine bay, but as it doe's not do it while standing I have no idea where to look. The turbo might be the obvious place to go but don't want to go raking about in there if I don't have to.
Anyone had similar problem?
Next is the brakes. While creeping to say a junction, foot on the brake it slows down then locks suddenly and then sometimes stay locked and need a bit of throttle to go. Have changed the load sensor, bled the system and new fluid in and new pads on front. Since doing this the pedal now has a lot of travel before biting but it will stop on a sixpence. And they still stick and lock on now and again.
Any help would go down a treat
