ATF Additives
  • ATF Additives
    Anyone use or recommend an ATF additive? Or are they all snake oil?
    Re
    I'd use one if it would keep the oil cooler!
      an additive that promises to do what?
      私のホバークラフト は鰻が一杯です。
        To do what it says on the tin/bottle/packaging.
          smartarse
          whats that then?
          私のホバークラフト は鰻が一杯です。
            smartarse
            whats that then?
            It's the thing they put the additive in so it doesn't make a mess all over the shelves in the motor factors.
              They're supposed to make the gear changes smother and prolong the life of the oil.
                http://www.atra.com/AM/Template.cfm?...CONTENTID=1278
                私のホバークラフト は鰻が一杯です。
                  So which ones do work?
                    None, most likely.
