air con fans removal
  • gwh200
    replied
    Ahhhh... tWas the great windy one that removed it.
    there was an earth wired possibly, by a previous owner which when I connected back up stopped the drain. I think it was from an immobiliser. But your right I just had crappy luck ( and me vince, stein and bio trying to reassemble the dash before the rac arrived)
    Leave a comment:
  • MattF
    replied
    Sounds like you just had crappy luck when you removed yours Gra.
    Leave a comment:
  • guysturg1
    replied
    Originally posted by dan222 View Post
    has anyone else had this problem of not beign able to start the engin after removing the fans, ?
    not had a problem at all
    Leave a comment:
  • BUSHWHACKER
    replied
    Nope.
    Leave a comment:
  • dan222
    replied
    Thanks To All
    sounds like thats the way
    cheers for all the advice , thanks to all
    ,Dan.
    Leave a comment:
  • MattF
    replied
    Not personally. You can easily check before removing anything. Drop the condensor rad but leave all of the hoses connected and disconnect the connector for the fans.
    Leave a comment:
  • dan222
    replied
    Leave a comment:
  • gwh200
    replied
    Please bear in mind that removing the loom from the fans can give you starting issues. In my case it was an open circuit that would not allow the starter relay to energise. tWas a eight bugger to diagnose. As for the rest of the aircon ... It's all easy to remove.
    Leave a comment:
  • BUSHWHACKER
    replied
    no i just want to get rid of the 2 fans as i think takeing all the air con out would be to mutch work,
    cheers ,Dan.
    No big job.
    If your air-con has never worked then chances are that all the gas has evaporated anyway so just unscrew the pipes and drop the rad down.
    Remove pipes from compressor and remove it, and them too.
    Leave a comment:
  • dan222
    replied
    It's just four bolts to drop the assembly off. Getting the pipework out tends to take longer than removing the fan assembly. Are you removing the aircon system completely?
    cheers ,Dan.
    Leave a comment:
  • MattF
    replied
    Leave a comment:
  • dan222
    started a topic air con fans removal
    Hi all
    as any one removed the air con fans from under the engine , as i wish to take them off for good, but need to know if this is a hard or easy job to do ,?
    any advice will help, thanks , Dan.
