removing lift kit
  • removing lift kit
    Hi All
    I belive my surf has a lift kit as i have a 1.5/2 inch gap between the chassie and body tub now i want to remove it and put my surf back to normal any body know how the body is fitted to the chassie ? is it justed bolted stright on to the chassie and if so what size bolts are needed?
    dom
    Yes, the body is bolted to the chassis in ten places.
    One below the radiator, one in front of the front seats, one behind the front seats, one under the rear seats and one below the boot floor.
    The same down the other side.
    You could re-use the bolts that are fitted at the moment and cut off the excess.
