Hi All,
I had a very eventful journey back from London to Edinburgh yesterday. Having noticed some drips of oil in the morning coming from what I thought was the rear of the engine, I checked the oil level and sure enough it was a little low. So I topped it up and left to see how bad the drip was. It didn't seem too awful, so I set off about an hour later. About a couple of hours in I noticed the Oil pressure guage was hovering between at the top of the first bar low level but dropped to zero when I was sat in traffic idling, so at the first petrol stop I checked the oil levels with the dipstick, but all apeared fine. About 420 miles along and 70 from home in Edinburgh, I suddenly loose all drive to the wheels. Engine is still turning over fine and the gears are still changing ok, but no drive at all. On inspection, there is oil all over the diff / gearbox at the front and it has given a good pebbledashing to the prop and underside. The oil doesn't smell like gearbox fluid, and that makes sense as the gears seems to change ok.
After a nightmare with the AA, waiting 2 and a half hours to get a truck out to me, I eventually get the truck back on the driveway at 2am. Pigging nightmare.
Looking at it the following day, it looks like there is definitely oil coming from the rear crank oil seal. There's also oil around the front diff and over the bell housing although I think this may have spread down from the crank seal. I'm guessing that oil has contaminated the clutch, hence no drive although I'm also worried it may have been DMF letting go? I've only moved up to Edinburgh recently, so my usual mechanic is based in London. Does anybody know somebody they can recommend up here? Oh, and does anybody know how much I'm looking at for a new clutch, new seals and service? Is there anything else I should get done at the same time?
Thanks,
Shaft
*Broken - 1992 Japanese 2.4td Surf with 2.5" bodylift kit and 33 12.5 15 tyres.
Thanks,
Shaft
