changing water pump
  • changing water pump
    hi would it be advisable to change the water pump as i am just starting to replace the cylinderhead and gaskets as imy surfs been sitting on the drive for a year never had it overheat just white smoke,,only to find a couple of cracks in the head,, also i will be buying a new cam belt,, the tentioner and pully is that a must that needs to be changed.. thanks alex
    Yes change the lot including the three seals (crank, cam and I think the other is oil pump on a 1KZ-TE). The hydraulic tensioner is expensive, so you may want to just check it's operation and check for leaks. If ok you can reuse it.
    Nev
    Edit: Put your vehicle details in your profile so we don't have to search for what vehicle you have.
      hi thanks mate for the advice just sets my mind at ease with what i need to do, want to do it right first time,, never done anything like this before. alex
