Air Conditioning
  • Air Conditioning
    Howdy
    Well, I just tried my air conditioning and it didn't seem to make much difference to the inlet temperature - it certainly wasn't a 'biting wind' like other cars that I have driven with air con.
    Is this something I can look into myself (ie anything obvious, like fans not running etc) or is it a specialist job?
    Oh and please don't tell anyone at work - I'm responsible for the air conditioning on Tornado fighter aircraft, and this would be embarrassing!!
    Rob
    Originally posted by robnw67
    Howdy
    Rob
    might need regas... need to go to air con place for that.
      Howdy
      Rob
      wharton or salmesbury
        lift the bonnet with engine running ask someone to turn AC on & watch the pump to see iff inner wheel turns
          Mumblings
          Warton
          Apparently the system was re-gassed in September 2003, but I guess that doesn't rule out if there's a leak.
          I'll check the pulleys tonight - see what happens.
          There may be a slight almost imperceptible drop in temperature when the air-con is on (difficult to tell) and I am wondering if there is a heat exchanger somewhere with a fan that's not working. Does anyone know how the fan works, if it exists?
          Alternatively, any good air-con places in Preston?
          Rob
            Warton
            Rob
            Rob.
            The aircon rad is either under the engine at the front with two fans on top or in front of the main radiator with 1 fan on.
            Things are obviously getting a bit too plush in fighter aircraft these days if they got aircon in them - what next CD players and leather upholstery.
              Originally posted by lucky
              Rob.
              i'd prefer a heater!... doesn't it get cold up that high!
                Hot or cold
                Well, you're right - the air con on jets works both ways - hot and cold.
                Afterall it may be +50°C on the ground an -65°C in the air - there's quite a temp range to deal with.
                  Update
                  Hi
                  Well I took a look at the system that I have and I have the type where there are 2 fans over a heat exchanger under the sump - both fans seem to be operating ok.
                  I checked in the little spy glass on the condenser unit and couldn't see any evidence of flow. I then checked the compressor unit. When I pressed the a/c button there was no difference in how the unit behaved - there seemed to be one pulley wheel inside another. The central part of the pulley remained stationary at all times.
                  There was a little plastic connector on top of the compressor unit - I stuck a volt meter across it and there was no voltage regardless of a/c switch position - is there a fuse blown maybe - if so, anyone know where it is?
                  So is the system FUBAR and needing expert help - or is there something else I can check?
                  Rob
                    well your not getting power to it so thats a start
                      Direct Supply
                      Do we know if it's a 12v compressor? Should I try putting 12v directly to the connector and see what happens?
                        Partial Success
                        Well - I have achieved partial success - I connected a 12v supply direct to the compressor and it runs. I am not sure if the air was particularly cold because it's chilled down here. But I'll try it again tomorrow in the heat of the day.
                        I guess the switch controls a relay and has a fuse somewhere - anyone know where these are so I can check them out?
                        Rob
                          You also have a switch somewhere in the system that stops the compressor from working if it's low on gas, so be careful that you have not bypassed that.
                            Making sense
                            Aaah cheers Andy - that makes sense - I may just have a leak in the system. I guess it's time to call in the professionals!
                            Cheers all for the advice
                            Rob
                              Rob.
                              Theyll be going back to basics shortly-pilots will have to cut down on the beer, tea/coffe and biscuits, what with the extra weight on the new harrier replacement [JSF] and all LOL. Just like the yanks...remember Jet Propulsion Labs....working in different measurements....or like the first F16's that decided to fly upside down when it crossed the equator LOL
                              Gaz
