oil leak
  • oil leak
    hi
    need some assistance.
    i have a oil leak coming from the rear of the engine and gearbox but cant see exactly where.
    the engine is loosing no oi, so slightly confusing.
    any ideas where this may be coming from and possible remedies?
    thanks
    That'll be the rear crank seal. Thats a big gearbox to remove, good luck if you tackle it yourself.
    Ebay search item 230357761354 !
      Could be rear main (crank) seal but check the rocker cover and the sump first before you rip the gearbox out.
      Nev
        oil leak
        engine now out and a bit of oil around the rear seal but alsolooks like the seal in the torque convertor
        any ideas where i can get one.
