I have a 2.4 diesel Surf and have been delighted with it for seven years. For the last year it has been out of action. It started to leak fuel so the pump was reconditioned. Then it started to smoke. No compression on number one cylinder- cracked head and loose valve seat. New head, cam etc. Still low compression - rebore. Now it started badly and ran lumpy for a few minutes but ran beautifully after that. When the electronics were disconnected from the pump it started immediately but wouldn't run properly - too advanced.
New crank sensor fitted and switch put in to isolate electronics for starting. Seemed to work briefly.
Now engine is permanently fully advanced with code 12 showing and can't be driven. The Garage has had the pump thoroughly tested and overhauled and has checked the timing and the wiring continuity. As far as they can tell there is nothing wrong but it will not come out of full advance.
Does anyone have any ideas at all? I am getting desperate as I have now been without the car for a full year.
