Originally posted by MattF
View Post
When searching for mine they seemed to come in several varieties.
The cheapest were pretty much the same as standard car batts, with the plastic plugs for topping up.
Then you had the sealed wet acid type.
Then various gel types.
The prices go up and up..... Lots of 'psuedo' gels / calcium / blah blah blah stuff.
I ended up going for a lucas sealed acid type as it was the best match for my budget and amp/hr requirements. Obviously there are better batts available but hopefully this will perform as it should for my application. (running a fridge overnight at campsites where no electric hook up is available)
It will be clamped to the boot floor, inside an ammo box with a pipe venting to outside.
What 'finnikiness' are you refering to re: charging?
Rob.
- naked bloaters with voltmeters . com
