I'm a new surf driver, purchased the "ZULU" from BlackpoolSparks about 8 months ago, Great machine. I had some trouble 4 months ago when the Drive Belts went on my way to Oxford. I replaced them but in the process I drained and removed the Rad. I properly should have read up more about the coolant but I have replaced the coolant with what looks like blue coolant.
About two weeks ago I started having problems with over heating. Seems ok when I was running, but if I'm sitting in traffic it gets a bit hairy. I have to keep the revs up at about 2000 RPM to keep it in the green.
I know this is my own stupidity, but is there any advice any one can give?
Before this gets to long winded I'm planning a trip down through Africa. A friend of mine in Moz says he has over heating problems and was told the Surfs don't like the Heat is this true?
Any help is greatly appreciated
Thanks
Don
Thanks
Don
