Hi, I've got a surf s.s.r.x 3.0 limited 1993 (don't know whether this is relevant) i brought it sept last year but the back window has never worked properly it used to go up and down but only with a bit of help with my hand, but as off yesterday there's nothing when you turn the key, i was advised to check the fuse but as im not the mechanical type wasn't sure where the fuse was for it so checked the ones i could find under the bonnet and under drivers footwell but no luck am i missing any? someone else mentioned the motor might have gone are they easy to get hold off?
Any help or advise would be greatly appreciated.
