Just found a small pool of oil/grease by my drivers side back wheel (just the smaller darker patch) this is about 24 hours since I parked it in that particular bay
[IMG]
[/IMG]
On inspection the oil had dribbled down the back of the tyre from the rear of the drum. The top and bottom of the rear of the drum are covered in a thin layer of oil/grease (seems like grease to me) there is a bit of grease on the inside of the top of the wheel arch which I guess is spray and nothing on the body of the shock.
[IMG]
[/IMG]
It is coming through the front slightly
Any ideas. I am, bear in mind a mechanical numpty. Diff oil? Oil from the hub?
Diff oils were changed recently by toyota.
Any advice greatly appreciated. Sorry pics arent great, it wasn't that light.
[IMG]
[/IMG]On inspection the oil had dribbled down the back of the tyre from the rear of the drum. The top and bottom of the rear of the drum are covered in a thin layer of oil/grease (seems like grease to me) there is a bit of grease on the inside of the top of the wheel arch which I guess is spray and nothing on the body of the shock.
[IMG]
[/IMG]It is coming through the front slightly
Should do the job!
