Hi surfers I have a problem with the tail gate window on my K plate 2.4. It's stuck in the up position tried using the key and the button with no luck, I have noticed that when I press the button to go up the interior lights dim so I guess there i some power getting to the button. Any ideas on how to trace the fault? could it be a relay.
Tyton
PS I had just changed the engine and transmission oil when I found out about the window do one job and make two more
Tyton
