auto gear stick
  • auto gear stick
    can anybody help? i can't get out park position. it will let me select any drive position if i push the red button though.
    Have you got your foot on the brake pedal if not it won't let you move the stick. If you have then I can only guess that the switch from the brake pedal is not telling the stick it can move if that makes sense.
    I'm a custard donut monster
      check your brake lights....if they don't come on at all then the brake switch driven by the pedal maybe nackered. You should be able to hear a relay/solinoid firing when you press the brake pedal. This releases the shift level so you can select a gear.
      Mart
      ......surf's up pal!
          thanks everyone, but it was only a fuse. What a silly billy am i. Ha ha ha
