hello people,ive got a ln130 2.4 and the tailgate lock that makes the window go up and down has stopped working.ive tested the plug at lock end and theres 12v at the swivel bit that the lock moves so it cant be that.ive even tried bridging the plug to mimick the lock but window does nothing.has anyone come across this problem or am i just being thick?any help would be wicked.
rear tailgate lock not working
hi yer just fitted new recon unit that i got from lord lucon on here.the lock packed up before the motor went.defo aint the window switch/lock and aint wires to the lock as theres a 12v suply to it.Originally posted by adpsimpson View PostMight also be that the motor has died, or its cables have snaped. Can you raise/lower the window from the switch inside?
should there not be +12V to both sides of the lock, and depending which way you turn it which one is given earth to complete that circuit? Could be wrong, but i know you give earth to one wire out of the relay box to raise the rear window, and to another to lower it.=========
=SOLD UP!=
yer thats right,i get 12v one side and 8.6 the other.tried bridging the wires and the motor should go up or down if chayounge the polaraty.nufing happens?im stumped unless the relay is buggering about.Originally posted by nero279 View Postshould there not be +12V to both sides of the lock, and depending which way you turn it which one is given earth to complete that circuit? Could be wrong, but i know you give earth to one wire out of the relay box to raise the rear window, and to another to lower it.Last edited by solberg1; 10 March 2009, 20:46.
i mean im doing exactly what the key would do.and nothing happens.Originally posted by nero279 View Postif you're bridging the two positives together nothing will happen, short one wire to earth and the motor should go one way, the other wire to earth and the motor should go the other way.
if you take the key assembley apart theres a contact under the swivel that the key turns.the middle of it is pos and the two outside contacts are earth.so in theory if u cross either side then the motor should move.Originally posted by nero279 View Postif you're bridging the two positives together nothing will happen, short one wire to earth and the motor should go one way, the other wire to earth and the motor should go the other way.
strip a little wire off further back from the switch and short that to earth and see what happens, if it's still nothing the fault is before the lock, ie) wiring or relay box.
Originally posted by adpsimpsonCan you raise/lower the window from the switch inside?=========
=SOLD UP!=
GOT NO COWBOYS HERE?
