Putting up this thread for other 3rd gen owners who want to put a front diff breather on.
re: this thread:
http://www.hiluxsurf.co.uk/forums/sh...light=breather
So, I wanted to fit diff breathers after lovely Flat Essex seems to flood more and more. (I drive to work down a road called Watery Lane......named for obvious reasons).
Rear diff breather - piece of pi55......easy to do, fairly easy to run the pipes up along the underside up into the engine bay.
Front breather....not so easy....I couldn't see it from above.......couldn't even see the diff. Couldn't see it easily from below.
Removed the two bash plates........still couldn't see the diff breather plug...
...spent 3/4 of an hour working my way with my fingers around the diff.
...found what I thought might be the breather...but it had something on it..
Eventually had a good look around in the engine bay and found what I think is a factory fitted front diff breather.
Googling throws up that the US spec 4runner had factory fitted front diff breathers.
...it seems mine does too.
Moral....if you have a 3rd gen Surf, check under the bonnet on the passenger side wheel arch....you may have a breather already installed.
re: this thread:
