Locking hubs!?!? i need help
  • Locking hubs!?!? i need help
    Hi everyone!
    It's Luke, I'm having problems with my "locking hubs". They aren't locking at all!!! Could it be there Fake!?! If so where might i be able to find some real ones and what parts would i need?
    How do you know they're not locking? or rather unlocking? Can you turn your half shafts by hand, when they are unlocked?
    私のホバークラフト は鰻が一杯です。
      What do these 'locking hubs' look like?
        They should look like these,
        http://www.roughtrax4x4.com/?doc=16&cid=148&vid=1139
          The hubs won't lock and i'm able to turn them from the unlock position to the locking position with no results.
            Have you got the transfer box in 4wd?
              There pretty simple on the inside.
              Best google a service kit for the make of the freewheeling hubs. Its normally just some springs an cr*p..
              Simple enough to remove them ... just wear goggles so you dont blind yourself when a spring goes pop!
                i have pictures but can't figure out how to post pictures,
                  Put them on Photobucket and paste the IMG code into your post.
                    do u think they could be fake?
                      Don't think so, they look real.
                        Well thats a relief! I'm going to take them off tonight and take a look, what sorta things should i be looking for? Also how do you post a profile picture?
                          Have you done what I said in post 6?
                          To get a custom avatar, you need to pay your subs.
                            i'm not sure what it is.
                              Ok, Keep it simple in case i misunderstand what your not sure about..
                              Lever next to the gear select level... you push it forward or push the button the side to engage 4wd. Without that being selected the free wheel hubs wont have anything to actually engage.
