OK, I'm stuck.....
We took Nina's truck to Avon Dassett a few months back, got it good and dirty, smashed the fog light off - you know, usualy Christening stuff....anyway, since then, the brakes have been very poor.
The brake warning light would come on when accelerating, and now it's on the whole time. I've checked the front pads, OK, rear shoes, OK, checked the fluid levels, OK, checked the ABS sensors and cleaned them up, jet washed underneath to clean up the handbrake bits and cleaned the rear brakes.
If I pump the brake pedal I get good pressure, but if I just put my foot on the brakes the pedal goes almost to the floor.
In my current physical state I can't spend too much time crawling about under it, but need to find the problem and fix it asap, so any help in diagnoses would really help.
TIA
TIA
