Hiya,
Finally got around to changing the ATF, went to the Toyota dealer as I figured they might know what the surf would be ok using. Anyway the only option they had was dex 4, I know everyone says 3's compatible and it should take 2 but either they were being particularly unhelpful that day or didn't know.
I'm only doing a sump drain/refill a couple of times so will end up with some 4 mixed with 2 (or 3), anyone got any ideas if 4 is ok (apart from the cost).
Ta
Sorry, quick edit on the type of oil 4 not 5!
Ta
