Does anyone know If you can safely mix dextron 11 and dextron 111
transmission fluid? I guess maybe you can as I have topped mine up with dextron 111 and It appears fine, but maybe It already had dexrton 111 put in the box in Japan? Trouble is you have no idea whats been done (or not) before it arrives in this country.
I was going to flush and refill with dextron 111 but i have heard many times that if It's ok leave It alone!!
Think I'll do that ........It's also a lot cheaper!!!
