Hi guys, I just got a set of extended brake lines from Roughtrax, but I am at a loss as how to use them. There are three lines, two short, one longer. however, neither are as long as my existing hose from the load sensor to the brake lines.
Dumb Question -
- do i connect two together to make a longer one, or am I just, er, dumb?
Also, it says summit about crush washers that 'come with the kit' but there was nowt int he plastic container except the 3 hoses.... Are the crush washers on the lines already? Am I missing them? am I just missing a brain??
anyhows, any advice accepted, useful advice accepted in preference to any other....
cheers mateys
Dumb Question -
- do i connect two together to make a longer one, or am I just, er, dumb?Also, it says summit about crush washers that 'come with the kit' but there was nowt int he plastic container except the 3 hoses.... Are the crush washers on the lines already? Am I missing them? am I just missing a brain??
cheers mateys
