waxoyl is brilliant stuff abit messy to apply,
if you buy the waxoyl in the gallon size cans,
and put the can into a bucket of boiling water for a few minutes it goes really thin leave it in the bucket of water whilst you spray it on,
the application gun fits into the top of the can and is only about £8 and once you have finished the job wash the gun through with warm water and fairy liquid and all the waxoyl will come off no problem,
also when applying wear an old pair of overalls and put a blanket on the floor under the car because it makes a huge amount of mess,
what ever clothes you are wearing basically chuck them away as the stuff is hard to wash out,
it does protect the underside of the car big time,
ive been useing it for years on all my cars and they all still look like new underneath after years of abuse,
its good stuff mate,
the secret is not to let the water in the bucket go to cold keep it topped up with hot water,
and buy the black waxoyl as you can see it going onto the components,
i usually can do one surf including all the axles and back plates and props ect with 1.5 gallons,
so if you get 3 gallons you should have enough,
the clear waxoyl is so transparent you dont realise how much you are applying so you end up useing loads more as you keep running out,
i put the clear under my nissan when it was new and ended up useing nearly 3 gallons,
