power steering probs ?
  • power steering probs ?
    ello all
    the stearing on my 2.4 .. 93` surf keeps going heavy - needs alot more effort the steer .
    the probs been there for a while but its gettin worse ! more noticeable with less rev`s at cross roads u know ?
    the belts seems tight
    no oil leaks (but the oil is dark)
    the pump looks like a bu""er to change is it ??
    chears tom
    Its quite straight forward, once the airbox, radiator, thermostat housing, inlet manifold and injector pump are out of the way.... I pulled one off my breaker today. (You don't really have to take all that off....)
    it's in me shed, mate.
      thanx mate
      should i be havin the pump / system ,tested 4 pressure ??
