Repacking & Servicing Front Wheel Bearings
  • Repacking & Servicing Front Wheel Bearings
    Hi All,
    I just noticed a "squealing" and "whining" noise coming from the front wheels.
    I used to put the whining down to the tyres (General Grabber AT2's) but since it has gotten worse I guess it is now the wheel bearings.
    I also put Wheel Spacers on about a year ago which probably puts extra stess on the bearings!
    Before I shell out large amounts of cash on new bearings I thought I might repack them and service them and see does it sort it!
    They haven't been re-greased in about 5 years or so!
    I have a few questions!
    1. What grease do I use?
    2. How much do I need?
    3. How will I know from sight etc. if I need NEW bearings!
    4 What is the torque setting for the 55mm retaining nut?
    Having seen the tech write up on the Aussie forum I am none the wiser, (it is pretty vague! and could have been done better)
    Can anyone explain to me how to do this?
    Is it just a matter of removing the bearings and getting as much grease as I can packed in there?
    BTW I have WARN Free Wheeling Hubs.
    I REALLY APPRECIATE YOUR HELP!
    Gary
    If they're that noisy, they'll be knackered. They are available from Milners and Roughtrax (RTrax slightly cheaper) for about £30 a side.
    The big nut shouldn't be torqued up or you'll fry your bearings. Just tighten it to half a grunt, spin the wheel a few times to seat the bearings, loosen off the nut then re-tighten it just over hand tight. The lock nut will stop it loosening.
    You dont need a big expensive socket either (or one of those cheap ones which aren't the right size), a pipe wrench will do the job as they wont be (and shouldn't be) very tight.
    As for grease, just to the level of the bearing itself - which is a fair bit! As for grease, a wheel bearing grease, believe it or not :-)
    Its an easy job.
      Re
      Cheers buddy!
      I think I will try repacking 1st though!
      Might be because they are dry & haven't been done in ages!!
      Gary
