is there a differance in gear ratios between the 2.4 and 2.8 gearbox?
2.4 2.8 gearbox
I think gear ratios are all the same, ie, if you have R151 any R151 will be the same, if its a W series manual, the numbers after the W are the ratios. ie, W50 W55etc...Originally posted by barry007 View Postis there a differance in gear ratios between the 2.4 and 2.8 gearbox?
So find the id plate on your gearbox, and get the same.4x4toys.co.uk - Keeping you on and off the road...
