If you are planning on servicing your disk calipers, and like me find upon stripping that one of more of the pistons are seized, i have found an easy way of removing even the most stubborn and rusty pistons, some of you may well be aware of this, i worked it out after bashing the f**k out of one of my pistons in a vain attempt to free it... :s
With the Calipers still attached to the Hub Carrier, remove the pads, then chock the pistons that are not seized, so all the hydraulic power goes to the seized piston, and press the brake pedal !! and hey presto, out it pops
wish i'd of worked that out on the first one...
just thought i'd share that one with you guys
take it easy!
wish i'd of worked that out on the first one...just thought i'd share that one with you guys
take it easy!
