Hi all just got the new truck back from a check over at the garage yesterday... still don't quite trust myself... got quoted £300 (or around that to fix) for...
Both cv gaiters perished (see link at bottom of post for all pics)
residue oil leak
front brake disks low (thought they were pads?)
fog light out
service 80% foot brake (is that good or bad?)
service 70% hand brake (is that good or bad?)
(Quoted £180 for the brakes & 1 gaiter... parts & fitting)
Spoke to a few of you lot about changing the brakes & i may have a go at that myself (found the link) but not so sure about the cv gaiters as i don't really have the time or the tools (the way my luck is going at the moment the blinkin thing will fall to bits....).
Wanted to know your opinion as to whether the gaiters actually needed replacing as to me (uneducated i know) they don't look that bad?..the stuff on them is from my hands as im still sure there is an oil leak (not residue from rocker cover gasket being changed).
Also i wanted to replace the original radiator cap as it looked a bit old and ordered a new one from the parts shop in town (didn't have time to get it from roughtrax).. and when i replaced it today (cap says 0.9kgf/cm (88kPa) 0.9 ...which i thought was the right one?) and let it run for a while i noticed the oil leak seemed worse & a small drip developed on the bottom of the radiator (please see 'a rubbish picture' on the link below) its a steady drip and doesn't look horrific but needs sealing... but when i put the original cap back on it stopped (radiator level is ok but noticed bubbling sound... so will burp system tomorrow)...no over temp & seems to be running ok apart from a slight squeek from the belts (prob new belts noise?... don't think its the harmonic balancer...that went on the last one!!)
please see below for the pics & thanks again to everyone in advance!! (sorry for the long post!!)
http://s282.photobucket.com/albums/k.../surf3lengine/
Oh and i know there looks like an oil factory exploded underneath but haven't got round to blasting all the crud off it... missus had me putting all the nice stuff on...looks good tho!!
residue oil leak
fog light out
tried to take the passenger side front wheel off to check the brake pads etc but cant get the piggin wheel off!!!....... goin to go back to the garage & ask how he inspected the brake pads without taking the wheel off ..... either means he didn't take it off ....... & is trying to make some easy money by talking b*****ks (thanks for the ideas about the gaiters .. everyone at work thought they were ok too)... or he has messed up the wheel & should sort it???.... think it just hasn't been taken off in a while but cant seem to get it off.....maybe could get him to sort it???.....Karma payback for charging extortionate prices!!!
