Bottle jack
  • Bottle jack
    Anyone care to let me know if I have the right jack equipment? I've attached a pic of the jack and other kit that came with the car. There's the bottle jack itself, a long bar that hooks into the jack, and a wheel nut remover. My problem is that I have no hand handle to wind the jack up. I originally thought the wheel nut brace might link onto it, but its out by 2mm each side.
    If I can find out what I''m missing I can give someone like Streetluge Chris a pm for the part.
    Cheers.
    Everything's easy, when you know how!
    Have you got 2 tool rolls hidden in the side pockets in the boot
      Cheers.
      Thats the one, handle should be in the tool roll, like I found when I had my first puncture in myu Surf, unlucky for me I din't have a tool roll in mine, luckily I did have a pair of mole grips.
      Personally I'd give up on the standard bottle jack it ain't worth a light unless it is on perfectly flat and solid ground, get a decent aftermarket one or even better get a strong and extra strength scissor jack and a decent trolley jack to keep at home.
        Nope, no tool roll inside. I've got access to a very heavy duty trolley jack when I'm at home, but how often do you get a puncture on your driveway!
        I'll keep an eye on e-bay, and pm one of the breakers here, but if anyone has a spare.....
          heres a pic of the tools that come with the surf
