wing mirrors
  • wing mirrors
    can anybody point me in the right direction, need to strip down my wing mirrors. hav to replace one cover and tinker with the electrics on the other.
    do i start with the interior cover or do i start with the crome cover and work in.
    any advice will be greatly appreciated.
    you will need to remove the door card in order to disconnect the electrics and then prise the triangular plastic cover from the inside and undo the 3 bolts/screws to remove the mirror completely
      thanks, i take it once the mirrors off that they r fairly easy to strip.
        i think there is a bolt on the underside of the outer casing. once apart they can be a bitch to get back together
